Limey Offline OP
Last summer, I spun a main on my 97 SE V6. Found a 99 cougar engine with under 10 grand on it and installed eagerly. Started having a throttle hang problem. Had this happen once before (idling at 4000 RPM) and I replaced the IAC motor and cured it. Figured the same thing was happening again, so pulled IAC off of old engine and tried that.....even worse. So I replaced the EGR valve........nothing changed! Bought a new IAC and tried that.....ok for a bit and it started again shortly after, very intermittent though. Called ford and asked if the part numbers between the 99 cougar and 97 tour co-incided. As I suspected, they were different.So I tried installing a 99 cougar IAC (new).....still no luck. Is it possible that the computer in my 97 is not accepting the 99 cougar IAC? And on the flip side of that, is the 99 engine not accepting the 97 IAC?
Incase anyone is wondering how I know that it is the IAC causing the problem, I have a $36,000 scan tool sitting in my shop........they work wonders, besides that I can beat on the IAC and it will quit hanging for about 100 miles.
Any help would be appreciated. My thoughts were to put in an aftermarket chip for a 99 cougar, my co-worker seems to think it will work?
97 SE V6 MTX
custom fabricated quasi dual exhaust
3.5" brospeed tips
and a few other minors
has 99 cougar engine now....other bit the dust
Now with XM!!
Try the throttle hang fix located in the "how to's". It costs about 35 cents to do.
If it's true that we are here to help others, then what exactly are the others here for?
Limey Offline OP
trouble is, my IAC is still operating "open" all the time
97 SE V6 MTX
3.5" brospeed tips
Now with XM!!
