#49847 12/17/01 03:27 PM
Z
Z
I took the contour for a ride this weekend and after I passed a truck it started overheating. The fan did turn on, the coolant was not bubbling, the heater worked and I used it to cool things down a bit. It blew hot air indeed. However I was not able to move the car for more than 6 kms without it almost touching the red line so I panicked about messing it up and let it at a friends house and took a bus back frown frown
I read the FAQ and it says it can be the pump or the thermostat. It is a 1997 Duratec V6 and the band was changed 25000 kms ago. Any ideas??
Zevoruko
#49848 12/17/01 03:35 PM
Almost certainly the pump is missing a few blades or the thermostat is not opening. Theres a section on overhauling the cooling system on my web page
If youve done more than 50k miles change both
Mad Mole
Visit Mad Moles Mondeo Madness
2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc.
192 BHP, Faster than a speeding Duratec!
#49849 12/24/01 08:53 PM
Check the cooling fins on the bottom front of your radiator. I had similar problems and had the radiator replaced. The mech said most of the fins on the bottom of the radiator were folded over - blocking 1/3 of the radiator. The only thing I can think of is I used to take it to a detail shop and they used high pressure sprayers....
#49850 12/24/01 09:41 PM
If the water pump fails, the heater would not work.
The most likely cause of your problem is a stuck thermostat, but it could be any of several things that can cause a restriction in either the coolant flow or the air flow over the radiator. I would start by checking the thermostat.
Jim Johnson
98 SVT
#49851 12/25/01 03:49 AM
The tensioner on the belt is 'mickey mouse'. I have had the tensioner 'stuck' in one position, so that the water pump did not turn and thusly the engine ran hot. I now check the tensioner in the spring to be sure it holds its tension on the belt. (on a 2.5) It did not overheat and it was delivering heat through the heater probably by convection.
