Posts: 96 |
98 SVT, clutch masters flywheel, spec stage2 clutch, quaife ,y pipe. and only MOBIL-1 oil.
gansta a$$ 2000 Honda Civic on dope("nnnaaawwwzz").
ricers suck
KING OF ROAD RAGE
i need a center console and cup holder!!!!!1
Posts: 27 |
No CEL does NOT always mean "no codes" in KAM !
Posts: 3,732 |
anyone know what to do? this car is killing me in gas and i smell sulfur quite a bit (only since i changed an 02 sensor
Russell
Oval Port 3L Nearly Done
Posts: 16 |
As a # of others have noted, 24-28 mpg in mixed driving seems to be the norm. for the V6. Mine has improved steadily with new plugs, new o2 sensors, K&N OEM air filter, oil & filter change every 3-4K miles,one of those Bomb Mufflers/ebay,actually sounds pretty good so far, like an old Healy6,=less back pressure, and I'm convinced running 90+ gas has helped. I'm curious how long have you had the car, and was your milage ever better? By the by, the original plugs had 74+K miles and looked like 174K, the O2 sensors had seen better days also. The suggestion to check it out @ the Zone is a good one, unless you have your own code unit, but we wouldn't be having this chat if you did. Seriously it's probably the easiest and cheapest way to answer your question.
mike 95 SE
Posts: 3,732 |
ya my milage used to be 250-300 miles per tank
Russell
Posts: 3,732 |
can anyone help me, its killing me on gas !
Russell
Posts: 12 |
Poop.....Dont drive so much...that will help your mileage or how about trade it in for a civic! LOL Just kidding!  I get around 350 miles on my 99 SE Sport. Hope you get it fixed!
Posts: 771 |
I've had my 2.5 ATX Mystique for 105,000 miles now, and I commute 100 miles daily to work and usually another 300 miles on weekends, all Interstate driving at 65-70 MPH on cruise control. I've consistently gotten between 28.5 and 31.5 MPG with this car, the worse mileage usually in the summer with the AC on all the time. I always get 300 miles before I fill up, which is at least before a quarter tank.
-Mark-
'99 Mystique LS, totally original (including the original water pump and the premium stereo)! Bought new in December 1998 for $21,000.
208,000 miles
Posts: 62 |
I've just bought my 95 Mystique V-6 MTX with 146k on it and I get 275 to 325 on a full tank. I've suffered an all time low MPG at 240mi/tank. Kind of makes me miss my 450mi/tank Escort.  At least till I hit the gas pedal and go, go, gooooo. Although the all time low happened when I was screwing with it because of clogged EGR ports at the throttle and crazy TH because of the IAC. I still get a CEL but the code indicates that it's the TPS (throttle position sensor) which might have contributed to the crazy TH.
1995 Merc. V6
Finally... my 2 sets of MB Quarts PSC-213's have a good home.
10 McInstosh Sub
Pioneer 8200R Head
Pioneer 944 Amp
Posts: 3,732 |
the milege seems to ahve gotten worse since my new 02 sensor... maybe ill put the old one back in, even if i egt a cel, i think i might get ebtter milage
Russell
