#460616 10/17/02 02:11 AM
Well today I was going around a long, sharp, right hander and all the sudden I felt this sudden jerk and I heard this popping sound up on the right front of my car...
I drove around for about an hour and it keeps on making this same popping sound and gives me a sudden jerk.....
The funny thing is it only does it on right hand turns!!!!
I love this car but, but ,but .........
Please help
1998.5 CSVT #3617 K&N Custom Intake Custom 2 3/4 Magnaflow cat back Ram HD Power Grip Clutch Energy Suspension Inserts Bosch Platnium + Bf-Goodrich G-force radials "KDWS" Alpine deck CDA-7863 Boston mids More to come: Stock Sucks!!!!
oil starvation on right hand turns, I'd stop doing them dude until some experts pipe in here. . .unless you have an accusump and a gauge that reads your oil pressure, don't screw up your engine. . .
Sounds like a bad CV joint or possibly control arm bushings.
Stop driving it and start inspecting it already!
how much does it cost to replace a CV joint? I think mine is starting to go (same symptoms as TommyBoy). I will be getting my front end inspected when i put in my winter tires, but before they quote me for repairs i'd like to know how much i'm looking at and if i can do this myself. does anyone know what kind of work is envolved in replacing one.
95 SE MTX DH UIM, 65mm TB, SC CAI, Quaife, Centerforce, Fidanza, UR Pulley, F/R Strut Braces, Cross Drilled Rotors, S.S. Brake Hoses, 18" Enkei RS5, SVT Engine Mounts+Inserts, MSDS & y-pipe, Trubendz resonated exhaust & MagnaFlow cat
H
H
In reply to:
a bad CV joint
doesnt go pop pop pop
CV joints click when they are toast- not popping nioses- and as for oil starvation if his oil Psi light didnt come on nothing to worry about- check you springs though- Ive heard there is a recall on those
Tea 82 242Ti Proud former owner - Samantha '98 SVT #2253 Reborn Aug 21 2002 Cobra Paradise
The whole axle can be replaced at once which includes both inner/outer CV joints. This can be done with jackstands in your driveway/garage. The left (DS) axle was about $65 (with core) at NAPA. The right side is probably a little more because of the extra bearing support. (?) A Haynes manual is sufficient for the job. Might want to consider replacing the wheel bearing once you have the front end torm apart. (Figure an extra $85)
Oh yeah, AZ and Advance dont carry the parts and the dealer wants way more $$$.
That is not necessarily true. A WORN CV joint that still hasn't failed yet does what you describe, but one time I was driving my Mom's van a few years ago, and it went pop pop pop CLANK CLANK! And then I seen it on the road in the rear view mirror! Of course it happened on a corner while sharply accelerating.
'95 CONTOUR SE -Enkei 16s -SVT wannabe -Dual escapes w/ 2 1/2" stainless tips -True LED taillight conversion -Audi Xenon Projector Retrofit -Mp3 deck, dual 10s
Of course I think she had later said it had been clicking around corners for months before that
Well Demon, I took your advice and took the wheel off and did a visual inspection!!! The CV joint LOOKS Ok no torn boots or any thing!!!!!
Also upon further inspection I found that it does make this noise on both left and right hand turns, even at low speeds. If I turn the wheel all the way to on side and drive in a circle at about 5mph it makes the Popping or clonking noise about every 4-5 seconds but it seems to be a lil louder on right hand turns.......
Any Ideas??????
Also Demon the control arm bushing, is that the same as the A arm?
In reply to:
Is there any merrit to this post as far as the recall goes???
Also how do you check springs??????
Thanks in advance
