Compucar is located in North Augusta, SC. You can find adds for there system in any mustang mag. The complete system is under $400. I used to live about 15 miles away so my system was around $365 with bottled filled.
2000 SVT contour Green w/tan KKM filter w/ a lil SQUEEZE 14.4 @ 100 m.p.h
Give the guys at Compucar a call if you have any questions. Also you fail to realize that if you do start pinging the comp aotu takes out timing. You'd be surprised how much a stock comp can take on making it's own adjustments. Now granted if I went to dyno it and get a custom program I could adjust all of that. I've had the bottle on the car for well over 6 months. The only problems that I have had were the tranny as mentioned before. No engine probs. I also check my engine on a regular basis. Aonther point to ponder. What about all of the N/A guys with all the mods. Or guys with the any off the shelf chip and then they add more mods. Chip is essentially a paper weight. Trust me on that one. Even ask Superchips.
Demon another thing after I posted is that I looked at your mods. You do something else to the motor to make it perform you can stop buying paper weights and use your chip when you pull it out.
