Posts: 2 |
hey ,you guys FWD? sounds like it...to the guy that dropped 75lbs up front,you might try ,adjustable shocks like tokico illuminas adj,set all four corners to the highest setting,this will help two fold,it will lessen the tendency for the front end to extend,and decrease the rear end from squatting,
I drive a CL typeS at 3750lbs. (w/driver) and FWD ,i know a little something about the launch, as i've gone 2.0** 60' over 10 times on street tires w/o shocks.
Posts: 1,191 |
Originally posted by typeR: hey ,you guys FWD? sounds like it...to the guy that dropped 75lbs up front,you might try ,adjustable shocks like tokico illuminas adj,set all four corners to the highest setting,this will help two fold,it will lessen the tendency for the front end to extend,and decrease the rear end from squatting, I drive a CL typeS at 3750lbs. (w/driver) and FWD ,i know a little something about the launch, as i've gone 2.0** 60' over 10 times on street tires w/o shocks.
What are your HP and TQ ratings????
Posts: 2 |
now ? 315hp 265lbft est. crank figures
Posts: 6,760 |
correct me if i'm wrong, but aren't those all ATXs? If so, its not hard to launch. If not then i'll shut up. Originally posted by typeR: hey ,you guys FWD? sounds like it...to the guy that dropped 75lbs up front,you might try ,adjustable shocks like tokico illuminas adj,set all four corners to the highest setting,this will help two fold,it will lessen the tendency for the front end to extend,and decrease the rear end from squatting, I drive a CL typeS at 3750lbs. (w/driver) and FWD ,i know a little something about the launch, as i've gone 2.0** 60' over 10 times on street tires w/o shocks.
Ryan
Trollin!
Posts: 1,977 |
Originally posted by Fmr12B: Stock Y-Pipe weighs over 45lbs with the SHOShop Y w/ cat weighing in around 13lbs. I assume the stock manifolds also weigh a ton so going to full headers would drop more weight. Straight pipe your resonator and you will lose a few more lbs.
I don't know about you, but I've had held 3 2.5L Duratec Y-pipes and none of them can weight more than 15lbs. I can say the same for the manifolds. Actually, I think the manifold weight less.
Posts: 670 |
Originally posted by RTStabler51: correct me if i'm wrong, but aren't those all ATXs? If so, its not hard to launch. If not then i'll shut up.
Maybe its because I've been driving a standard too long, but my wifes TL was a bear to get off the line. Turn off the traction control and it wants to spin all day long. Once it hooks up though, Whooo boy!
-R-
I'm a Karate Man. Karate men..bruise on the inside.
"The difference between oversteer and understeer: oversteer is when the passengers are scared, understeer is when the driver is scared." -Driver Unknown
Posts: 972 |
Originally posted by AirKnight: I don't know about you, but I've had held 3 2.5L Duratec Y-pipes and none of them can weight more than 15lbs. I can say the same for the manifolds. Actually, I think the manifold weight less.
I've swapped y-pipes about 6 times and the shoshop feels considerably lighter than the stock one to me. Not sure about 30lbs lighter, but at least 15lbs.
95 SE Modded - Gone
98 E0 Black SVT - Gone
98 se sport - Broken
00 T-Red SVT - Nice
Posts: 9,602 |
The entire stock 3 bolt flange Y-pipe unit weighs 31lbs.
Y-pipe itself = 13lbs.
Flex joint & cat = 18lbs.
Figure a 2-bolt flange unit maybe 3lbs less as a unit. (smaller, thinner flanges and no S-bend after cat)
My catless Y-pipe was around 7lbs.
The exhaust manifolds weigh 12lbs (rear) & 15lbs (front) respectively.
Headers maybe 5-6lbs each tops.
So headers and a catless Y-pipe drop around 40lbs total off the front of the car! (That's like an additional 5TQ off the line & 5HP at speed )
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 5 |
i have happen to see a silver contour svt go 12.6 on slicks cannot say who and where but it has been done, o yeah no turbo or supercharger.
Posts: 6,760 |
*raises the flag, and puts on the boots*
Ryan
Trollin!
