OK, I don't have the manual for the SVT, so the closest I have is the '96 SE (there are probably some differences). For camber (angle between the tops and bottom of the wheels) the range is about -.5 to +1.5 degrees, so you are probably in range. The rest of your numbers are very close (little difference) from left to right, so assuming that they were set to the right nominal values, it looks like a good alignment.
In the factory manual, the drive test is that it should take a car more than 7 seconds (at 55MPH) to drift from one 12ft wide lane into another. In FL you should have no trouble finding a flat, straight road to try this out on.
