I have about 90K kms on my car...should I change the transmission fluid? I don't know if it has ever been changed, and the maintenance schedule just says "inspect fluid level"...it never says "replace transmission fluid". The shifter's starting to get that peanut buttery feeling these past few cold days...maybe I'll do the "tranny cocktail". But what's the difference between ATX and MTX fluid? Could using ATX fluid in an MTX have undesireable consequences (i.e. excessive wear, etc.)?
1998.5 SVT Contour - Black H&R's Optimized Y-pipe and TB Open element intake w/heat shield 18x8 Mas Italy Axels (40 offset) w/225/40/18 2x Kicker 8" midbass "subs" in rear deck (infinite baffle setup) A few more little things...(like bushings)
I think I switched over to Synthetic at about 100,000 it does make a difference especially in the cold weather. I dont think there is any difference as far as ATX or MTX. Mobil 1 makes a Synthetic tranny fluid for ATX and that is what I use and most others I know use as well.
1998 BLK SVT CONTOUR #2980 of 6535 395,000(ish) km (and counting) SVTOA-TORONTO Chapter Director www.svtoa-toronto.ca
Change your fluid!!!!!!!!!!! Your tranmission will love you!
15.639 88.63MPH SVT Driver
Laura, did you do the "tranny cocktail" mix, including the Ford friction modifier? And what does the friction modifier do...make the fluid more viscous or less viscous?
That's strange...I just check Mobil's website and they don't appear to make an MTX fluid...why would that be?
2
2
Replace it. Your tranny calls for Mercon ATX fluid. Use Mobil 1.
A good rule of thumb, even though not in print is to change it as often as you would an auto tranny... every 50,000km. But yes for sure!!!! at 100,000km.
You will feel a difference
Former 1998 SE V6 Contour owner Presently Sentra SE-R SpecV
I just used Mobil 1 straight up. I didnt use a Friction modifier but next time i might use it. I think it helps to make things a little more smooth.
I use the friction modifier and it feels great.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
friction modifier, would i want to use that with my ATX?
97 T-Red LX ATX pre98 CF SVT front,SVT rear/side skirts FSVT wheels Custom Front Ford Logo (body Colour) 35% tint all around with sun visor WP With Metal Impeller? Elky Grills CTA Intake CTA Custom Dual Exhaust
NO.
Moderated by  Gerald_dup1, mbb41_dup1
