Posts: 3,774 |
So, I pull out of the parking garage while leaving work, and my car starts making this horrific noise from the rear suspension. It sounds like rubbing a hammer against a metal washboard whenever I go over bumps, accelerate hard, or brake hard....Esentially whenever the rear suspension moves. I'll take a closer look in the morning when it is light out. Possible problems... Springs gone? Shocks gone? Anything else? This friggin car is on the way out! Damn!
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 1,367 |
no chance its your inner fender rubbing on your tire? check that out thats an easy fix. mine rubbed (why i have no idea, i have stock tires!) so i had to cut a chunk of it off and voila, no more rubbing. it made an awful sound though when it did rub.
Posts: 268 |
Not sure what vehicle you've got, but check your sway bar bushings. My SVT started making hellatious noises almost overnite. Any time the rear suspension moved more than a tad. Finally got time to put the rear end up on my ramps and started bouncing the back end up and down while under the car. The sway bar bushings were the culprit. Pulled them out and greased them and now all is back to normal.
98 evo 0 SVT #2999 of 6535 Silver Frost/Midnight Blue Lotsa bolt-ons
Posts: 219 |
Should have sprung for that SVT on Ebay in Reading...  Can't believe it only went for $5500.
- Zack
1995 Contour LX 2.5L V6 MTX 150,000 miles and still going strong PIAA 510's (Finally I can see again!)
"It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it." George W. Bush
Posts: 3,774 |
Originally posted by zgendron: Should have sprung for that SVT on Ebay in Reading... Can't believe it only went for $5500.129k miles was a bit much. i'll wait till next year, there will be plenty of 2000's under $10k by that time with lower mileage.
Posts: 974 |
Now ya tell me about the fender thingy! I had sport yet stock 205's on and when in reverse I would hear thgis horrible suspension/ rubbing! I had alot more noises driving forward, but that one as the loudest of them all! But anyways, thanks for the info. NOW! JUst kidding, better late then never!!
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
Posts: 1,847 |
Check your springs just to be sure
95 Contour SE ATX V6 "Cracked" Secondaries DMD Installed SVT Brakes
