Page 1 of 3 1 2 3
svtnics Offline OP
well boys, i was going to go with 2.5 and just build it up but..then the 3L caught my eye which then lead to the 3.5L hard-on. does anyone know when the info/kit is going to be available? sho-shop won't reply anyway ...nevermind i know...use the SEARCH
export the imports
I read recently that the new Ford 500 will have a 3.5 litre V6...I wonder if this is the block that SHO SHOP is going to use? It didn't specify if the 3.5 was Duratec, but its not a bad thought.
O
O
Actually someone stated it was going to be a stroked 3L d-tec.
Fast Cheap reliable Pick two
That is correct. I called up and actually got to talk to someone. He said it was in the planning stages still, But it would be a stroked 3.0L.
99' Silver Frost SVT 18" Racing Hart C2's Fidanza Flywheel SPEC Stage III clutch Torsen Diff. Color matched Headlight covers Ding guards removed B&M Short Shifter Koni's and Ground controls NGK Iridium plugs
Bore out the 3L and add the stroker kit. Then you can brag about a 4L Contour. But it's just like SHO Shop, it'll probably never happen.
i also heard that teh next taurus will have a 3.5 litre SOHC motor which wouldnt be compatable with our heads.
Fifteen men on a dead man's chest... Maverick Machineworks is open for business!! Tell me what you need and I can make it!
Oh, it'll happen. We expect the 3.5L to be out in early spring. We already have a block ready, we're just awaiting pistons and the new crank at this time. As soon as more progress has been made, we will be posting it on our website.
There will be a revised SVT Catalog available by the end of the week on our website giving a short description the the 3.5L and projected HP numbers. We're expecting 250-260HP, which is similiar to our 3.6L SHO stroker kit.
Tom G. Manager/Tech - SHO Shop 714-894-8415 www.shoshop.com
What about longevity(sp?) Isn't that kills the 3.6 Yamaha?
Ryan Trollin!
What about torque estimates??? Damn, 260hp, going to be tough to pass this up. . .
D*MN*T!!
JUST WHEN I THINK I'M GETTING ON THE BANDWAGON THEY MAKE STUFF BIGGER!!
That rocks, I hope it's everything you hope - and we need!!
Now owner of 0 SVT's. my web page
Page 1 of 3 1 2 3
