Posts: 49 |
It worked
Thanks guys.
It only took like 20 minutes to get that ugly amber reflector out of my headlights thanks for telling me how to do it. I appreciate everyones help.
D_Freshzetec16_Racer 98 Contour LX, 5-Speed, APR Aluminum Wing, Xenon Bulbs, Corbra Eyes, 3A Racing Fogs, 17 Inch ICW Tuner Wheels Wraped around Kuhmo Supra 205/40's, APC Side Markers, Tinted Windows, Street Glow Purple Neon Under Car Kit, Superchip KKM Intake, Plugs and Wires, Dual Flowmaster Exhaust, Engine Dress Up Kit, Clear Corners.
Posts: 134 |
hey....how did you take it out? i want to take mine out now. if it looks better....do you think that it does???
95'contour se painted interior/calipers 220wt.3-way door speakers hyfonics 100x2 amp w/audiobahn 12'subs no performance mods
Posts: 49 |
Hell yea
I think it looks alot better with out it.
This can only be done on 98-00 contours.
Just unscrew the three screws holding the light in. Then pull out the bulbs (High Beam, Low Beam, Park)
Then once u have the headlight all the way out look where the reflector is and there are three lil spots that hold the reflector in.
Use a 1/4 Drill bit and drill in those three spots from the back of the headlight of course.
Then once u have the three wholes drilled u can see where the relector is held in. Just use a lil flat head screw driver and pop the relector loose.
Then shake it around till it gets near the hole where the high beam is and use somt tin shear cutters to cut up the relector then shake all the broken pieces out threw the hole.
Then just clean out the light and put it back in
Took me 20 minutes.
Oh yea and make sure to RTV the holes that u drilled in the back of the light.
LOL
Posts: 407 |
Oh yea and make sure to RTV the holes that u drilled in the back of the light. ???
2000 SVT Black & Blue #205 of 2150 Kenwood Head Unit
2001 SR5 4 Runner 4x4
Posts: 785 |
Originally posted by Danny: Oh yea and make sure to RTV the holes that u drilled in the back of the light. ???seal the holes make them water tight again... Later
Red '97 GL Sport MTX IVELISE ================================== "Let every nation know, whether it wishes us well or ill, that we shall pay any price, bear any burden, meet any hardship, support any friend, oppose any foe to assure the survival and success of liberty." John F. Kennedy
Posts: 1,225 |
Originally posted by Danny: Oh yea and make sure to RTV the holes that u drilled in the back of the light. ???RTV silicone...can pick it up at just about any auto store or probably your local hardware store too for that matter.
Ryan
Latest Mod: Mirko Splitter
Posts: 755 |
WHAT DOES THIS EXACTLY DO? WHAT DOES IT LOOK LIKE?
Spec 23
99 SVT No Mods (can't afford to void the extended warranty)
Posts: 2,809 |
minus the black painted interior...you get an idea...
