#452163 10/05/02 05:18 PM
H
H
My engine was running real hot so I go to check the coolant and it looks like it was spraying all around the resevoir. The coolant didn't appear to be coming in from any hose. Could this be a bad WP? My thermo reads high and my heater blows cool.
#452164 10/05/02 05:20 PM
H
H
Year of car? V6?
Sure sounds like the classic symptoms.
Both mine went in May.
#452165 10/05/02 05:40 PM
H
H
In reply to:
Year of car? V6?
Oops forgot that 98 SVT.
#452166 10/05/02 11:31 PM
I assume that the coolant blew out of the coolant bottle from overheating.
This is a classic case of a failed water pump. Water pump impeller has come apart. The true evidence is that the heater is cold even though the temp gauge is pegged.
#452167 10/07/02 12:51 AM
H
H
yup its the water pump, our pumps have a plastic impeller instead of metal one . so after about 50000 miles it can break and stop turning, if that happens it cant pump the coolant through the engine. i got rapped by my mechanic and spent 300+ on labor+ anew one, heres the funny part he replaced the broke one with a neither pump w/ a plastic impeller. If you felling up to it you can order a new one with a metal impeller from http://www.spmotorsports.com/
for 60 bucks and do it your self.
95 contour 2.5 intake,exhaust,removed resmagnecore wires --Superchip Blue module PEW4-- Battery Relocated
#452168 10/07/02 01:29 AM
the newer plastic one is supposed to be better. There was a post earlier today (I forget which forum) where the w/p was still ok on a 99 SVT with 61k miles. The w/p had the revised white impeller.
E0 SVT, lightly modded
#452169 10/07/02 04:28 AM
It was little old me...
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=general&Number=50206&page=0&view=collapsed&sb=5&o=2&fpart=1
Save your money and do it yourself. Just hope your impeller merely cracked instead of disentigrated...
JaTo e-Tough Guy Missouri City, TX 99 Contour SVT #143/2760 00 Corvette Coupe
