#451506 10/04/02 05:39 AM
Well i parked my car at work and ten minutes later went to turn it on and nothing happened. The only thing that worked were the interior lights and door locks. Everything else dosen't work not even the headlights.Have any of you had this problem with your car if yes/no can you give me some advice on what is going on or how i can fix the problem before taking it to the dealer. Thanks
#451507 10/04/02 10:10 AM
Z
Z
What year / engine / Miles?
Have you had the wiring harness replaced? Is all electrical dead? Guages too?
'97 Mercury Mystique GS (Not mine anymore...) Now running a Toyota Matrix XR Red, 16" wheels, Sunroof, VVT-i
#451508 10/06/02 11:16 PM
First check battery voltage and cables. A few things will work even when these factors are bad.
'98 SE V-6 5-spd ASB Silver stock 89K miles in May '05 Like it for Oregon coast canyons!
#451509 10/10/02 07:46 AM
Check the big fuses under the hood . the box is black and is just behind the battery . these are the big fuses . not like the ones under dash . Good Luck
