Ok ill tell you its kinda easy
Take out the screws about the steering coloum theres 2 then take out either the contour logo or the clock and remove those two. Use a small flat head screw driver to get out the clock. Remove clock and try to not step on it later
Remove your defrost switch also or you can wait until you take out the dash to do it. Then pull on the plastic dash part and the clips will let go. then rotate until it comes out.
theres like 6 or soo screws holding in the speedo/tach/temp/gas assmbly. Remove those and then remove the 2 harnesses from the rear of the speedo thingy.
theres a push clip or something on the whole assmebly thing and push one side and pull on the clear plastic part and it will come off then remove the black little trim peice.
now heres the rough part remove your needles but try not to mess with them too much and remember where they where.
do the tach and temp
then the speedo and gas
to remove the needles i used 2 small screw divers and pryed up. on the gas and temp the gold counter balance thing might come out. if it does put it back in and you should be good.
then when the needles are out place the indiglos over them try to center and put the black trim back on cuase that what holds the gauges in place.
put on needles
put clear thing on
reconnect 2 harnesses in the back
put screws in
then find how your gonna power then i found the parking light wirre can't remember what one it was
then hide the transformer part mount the knob part
and connect
test
then i went for a drive redlined my car and found the tach was 200 off not that big of a deal
speedo 5 mph high
ohh well also
but my gas is on e when it reads a 1/4 tank so i suggest you do it with a full tank and then put the needdle on full when you put it back on
and temp i have no clue how far its off
then put the dash peice on put in defrost
put screw behind clock
and above steering coloum and then put clock in and enjoy
wow thats long
and probably no help if you want to ask any more ?'s ill try to help
its easier to do then it looks trust me
any?'s just ask away
