I recently relocated my batt. to the back. Everything works fine but when i shut my car off and turn it back on my cd player resets (stations, settings, etc.)I know its cause of the batt. because when the key is in the on possistion before i start the car the cd player is fine but once i start it, the memory is wiped clean. I think it might be because of ground. i ran the ground cable from the batt back to under the hood and attached it to the old ground cable. was i not suppose to do that, am i suppose to ground it in the trunk? HELP
