...........after having my Hybrid Clutch and SHO LW Flywheel installed. My ceramic / organic material disc engages silky smooth! The organic material is bonded to a steel substraight to give it additional strength against bursting and tearing. The ceramic side gives it bite for the launches that I'll need later on when I have a transmission that can handel it. It also has a sprung hub to dampen input shaft vibrations. ( I can get these for any of you for $350, That's PP, Disc, Slave Cyl, and alighnment tool.)
But now my clutch problem is fixed, my transmission problem has begun! Now getting back from the shop it grinds going into 2nd. It was filled w/ the ford recommended ATF with the addative, and then bled....so it has to be the syncro's (IMO).
Looks like it's time for a bulldog! But does anyone have any ideas on how to limp this POS around until I can get ahold of one from HMS? I just want some other opinions other than my own.
