Originally posted by louisw:
Check that again. #9 looks like a relay.
Not so, relays have R in front of number.
My '98 owner's guide(with correction page glued in place) lists fuses 4,9 and 11 as feeding the EEC.
Fuse 11 feeds PCM (EEC) memory circuits.
Fuse 9 feeds PCM relay contact which in turn feeds power to PCU.
Fuse 4 feeds PCM relay coil, but only if ignition on. Pulling it is therefore actually redundant if fuse 9 is already pulled or if ignition is off.
Above for '98 models. As was posted earlier pulling bat neg for acouple of minutes is easier to communicate and avoids any model confusion re fuse numbers.
