Originally posted by makman10:
I have 2 eclipse alums and my trunk rattles hardcore. Im not really sure what to do but i dont feel like messing with dynamat. It sounds retarded outside the car too.
You will have to mess with some sort of sound deadening if you want the sound to go away.
License plate, trunk vents, and the 3rd brakelight/rear shelf are the main culprits.
To stop a plate from rattling, put a layer of dynomat on the back of the plate. It should at the very least, lower the volume/freq of the sound.
People have had good success stopping the package tray from rattling by stuffing it with a fiberfill like substance and put the interior piece back in. While the interior trim piece is out, make sure to dynamat the metal under it in addition to the stuffing.
While you are at it, remove the bottom of the rear seat and add a layer or two to the sheetmetal under it. It is a huge area for road noise to come through.
The trunk vents can be sealed off, but it may make the trunk more difficult to close, because it won't allow the air to be released. Instead, the air pressure, will act like a spring and make the trunk "bounce" back open unless you press on it firmly to close.
