#448092 09/29/02 09:00 PM
The attached is a good way for the diy guys to check oil etc....regards TH
www.racingarticles.com/articles_racing.30.html
#448093 09/29/02 09:16 PM
terry....link not work....
95 SE ATX Electric red mucho mods 2005 Scion xB Black Sand Pearl tinted windows red leather steering wheel US Army Mechanic
#448094 09/29/02 10:14 PM
Try http://racingarticles.com/article_racing-30.html
Also, if you don't want to DIY, you could send you oil off to a lab for analysis (such as http://www.blackstone-labs.com).
#448095 09/30/02 03:52 AM
I did that, the price isn't bad and they provide a detailed report and analysis (not just dry numbers).
E0 SVT, lightly modded
#448096 09/30/02 06:50 AM
it sorta works....redirects you back to the main site where u can find the article there on a list....
thanks terry
99 expedition eddie bauer, 5.4 v8, k&n drop-in, 3" magnaflow catback and gas mileage that makes the contour look like a hybrid
