Posts: 171 |
My low coolant light keeps coming on but its not low. It might be alittle under the max line but nothing the light should come on about. Any suggestions on whats the prob?? thanks Jerry
97 Contour Sport V6. T-Red, KKM tru rev induction, Ford racing wires, Cooper Cobras GTH, A pillar gauge pods with ford racing gauges, Clifford Matrix alarm, painted red calipers, full bra, premium audio installed,LED's, Ford Racing seat belt pads. It's my baby!!! I love to pull up to a honda or a VW and blow their "fast and furious" doors off. Imports can suck my american exhaust!!!
Posts: 128 |
The sensor likes for the level to be *slightly* above the max level. Just fill it up a bit and it should be fine.
1998 T-Red CSVT #3710/6535 Born on 9/23/97
Posts: 1,053 |
I got my coolant flushed and filled two weeks ago and it is about 3/4" above max. I still get the coolant on light when I turn on the car. I also get the fuel light too, regardless of whether it is full or empty.
MarkO
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course." #9 - Hitting .400 for ever "Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez "The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
Posts: 1,861 |
Originally posted by Import*Killer: My low coolant light keeps coming on but its not low. It might be alittle under the max line but nothing the light should come on about. Any suggestions on whats the prob?? thanks Jerry This is a Contour idiosyncrasy. They all do it. Changing parts doesn't help. The only thing that helps is to keep the level about 1/2" above the max line. There is a FAQ about this as well as many, many, many, many, many threads. It may be the most commonly asked question about Contours.
Jim Johnson 98 SVT
Posts: 7,329 |
Another common occurance is the senser eye get's a film built up on it. Easily fixed by cleaning it.
Posts: 93 |
It totally might not have anything to do with it, but mine low coolant light started to come on when I was full on coolant about a month before my water pump went. Just a heads up.
95SE ATX Champagne Mods: Levoc Chrome ATX shifter JPett's custom leather ATX shift boot
Posts: 336 |
Demon is right. In adition to the fact that the 'tour likes to have the coolant above the 'max' line, there is an optical sensor that can go bad. THe way I understand it is that if you collant gets a bit gunky, or a film developers on the inside of the while plastic coolant resivior, the coolant light can also be tripped. A good cleaning of the resivoir might also solve some fo the problems.
The Mark #464 of 6535 A Few GS-ish mods
Posts: 1,537 |
The coolant sensor also measure the SPECIFIC GRAVITY of your coolant mixture. If there is too much water, the light will come on also.
I would try to empty the reservoir, and then refill it with 100% antifreeze, and drive around for a day or two, and see if the light goes out.
Pete...
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Posts: 532 |
Mine comes on all the time too. I just ignore it. Seems to be come on after washing the car or when raining also.
Dan B.
