Posts: 26 |
I have 98 SVT with 44k miles. I am noticing a slight hesitation under light throttle. I just changed my plugs but that did not help. I will change the fuel filter soon. Additionally, I have experienced fuel starvation during high speed, long right-turning on/off ramps when I am low on fuel. I had a similiar fuel starvation problem in my 89 Ford Probe GT and it turned out to be a gunked up fuel filter intake sock - I cleaned it and cleaned out the bottom of my fuel tank and that fixed my Probe. I do not know if my two problems are related. (When I say my "two problems", I am referring to my SVT's symptoms, not my old Probe or my personal issues.) Any advice? Thanks - Dave
Posts: 211 |
Be carefull on them WOT right handers or you will have more than fuel starvation to worry about!!! More like oil starvation!!!!!
1998.5 CSVT #3617
K&N Custom Intake
Custom 2 3/4 Magnaflow cat back
Ram HD Power Grip Clutch
Energy Suspension Inserts
Bosch Platnium +
Bf-Goodrich G-force radials "KDWS"
Alpine deck CDA-7863
Boston mids
More to come: Stock Sucks!!!!
Posts: 163 |
a D*CK SLAP IN THE FACE IS ALL I GET FOR STICKING MY NECK OUT FOR A FORD... PLEASE DELETE MY ACCOUNT!
Posts: 26 |
Wouldn't a bad fuel pump manifest itself under heavy throttle and high rpm? I only have a problem under light throttle. I realize that most of you don't ever use "light throttle", but any advice would be appreciated. Can anyone tell me what and where the fuel regulator is?
Thanks - Dave
Posts: 246 |
Does it seem to get worse/better depending on the amount of fuel in the tank?
-neal
99 SVT ~ Silver Frost ~ #2621
mods? a few...
Posts: 26 |
I have not noticed any correlation with the hesitation and fuel level, or anything else for that matter. I will keep monitoring the situation this week and hopefully I can replace the fuel filter next weekend.
Dave
Posts: 163 |
Most tours with 35+k miles will or have experience the exact same problem and it is usually the fuel pump. The key is hesitation when turning corners. If there is no corrulation yet with fuel level, there soon will be as the pumps performance deteriorates.
Posts: 1,044 |
Might want to change the fuel filter and clean up the TB and EGR passages just to rule them out as a cause. Are you running the TH fix plug? Try pulling it out and see if it makes a difference. Also verify the MAF and air filter are clean.
Posts: 2,445 |
Hmmm....
I have had a hesitation problem with my '00 SE since I bought it used three weeks ago(49K miles). The problem usually occurs under heavy throttle and when i have a half a tank or less of gas. It has been not been acting up as much since that intial tank of gas (filled by the dealer), but when I go in for my "free" service next week, I can bitch because I had complained about this before I bought the car. The hard part was it was masked by that damn AC compressor clutch kicking in at first....but since I have experienced the problem at freeway speeds (slowed down to 30 before it cleared) as well, they BETTER fix it.
2000 Contour SE Sport
Originator of the Beowulf Headlight Mod and the Beowulf CAI
Posts: 14 |
Beowulf, I have exactly the same problem on my 00 Contour @ 29K miles when the tank is 1/2 full. Let me know if it turns out to be the fuel filter or the $250 pump. Thanks ____________________________________________ Originally posted by Beowulf: Hmmm....
00 SE Sport
SVT rotors & Mintex
Infinity sound
