#446600 09/27/02 03:47 AM
9
94ex Offline OP
I posted earlier about my O2 sensor causing the check engine light to come on, and looking at the Haynes manual and other CEGer's advice it looks like something I can do this weekend. Anyways when looking at the code list I see next to my code: P0153-Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 2. Does this mean that I only need to replace one of the O2 sensors? If so which one is it the front or the back? Any help would be greatly appreciated. TIA.
Austin -officially a troll See it here Pro-Flow w/ optimizer STILL for sale
#446601 09/27/02 03:55 AM
Do a search for O2 sensor or your code, there are tons of posts on O2's.
1996 Contour Sport 2.0L Zetek Ford Racing 9mm wires Exhaust resonator removed Magnaflow Muffler 2 MTX4000 12's, Pioneer DEH700 Deck
#446602 09/28/02 03:37 AM
9
94ex Offline OP
Can anyone else help me?
#446603 09/28/02 12:29 PM
Yes, the code points to one of the four O2 sensors (HO2S21 = Bank 2 Upstream) on your car.
Bank 1 is next to the firewall, Bank 2 is next to the radiator. The upstream sensor is next to the oil filter.
If the new O2 doesn't fix the problem (after you have reset the CEL), then the other possible causes (from the Ford TSP) are as follows:
-- Contaminated HO2S.
-- Exhaust leaks.
-- Shorted/open wires.
-- Excessive fueling.
-- MAF meter.
-- Air leaks.
