If I'm not mistaken, they sell coolant with ultraviolet dye in it. It is used to track down leaks. Once you have added this coolant and let the engine run a while, you would shine a blacklight on the engine in a dark area and you should be able to see where the leak is eminating from.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
