Is there anyone who is in need of new A arms? I guess I should say new bushings for A arms. If you've looked into the install on the left side it entails removing the transaxle to access the front bolt(s). I have a better way, but it means replacing the bolts. You'll have to cut the tops off them so they can drop down. Then replace them by pushing them up and installing the nut on top, which is the reverse of the factory mounting arrangement. I've got spare OEM bolts which have been cross drilled for safety wire or cotter pins. This is for safety in case the nut ever comes loose. Wouldn't want to lose a control arm on an on/off ramp at speed! PM me if you're interested.
BTW-Ford only sells them in multi quantity packages.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
