Be very carefull when you pop out the handle inserts, they get damaged rather easily. I used a flat-head screwdriver to pry mine off and ended up having to buy a new set because you could see right where I had apllied pressure with the driver.
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue
Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
