Posts: 134 |
Usually everymorning when its cold or just when the cars been sitting there during the day when its cold and I start my car, theres a humming noise coming from under the hood. The RPM raises and drops all by itself, up and down a couple of times and sometimes it will go too low and cut off. Does anyone know what this could be?? any info is appreciated.
Thanks, Nomi
N S K Nomi K. 99 red SVT Kenwood CD player Portable DVD kkm intake Dreamcast Interior Neons Underbody Neons
Posts: 75 |
Although my engine is a Zetec, I've noticed that the cooling fan will sometimes run for a bit when the engine is started. After running for a bit, the fan shuts off. Maybe this might be what you are hearing??..my $00.02!
Is the smoke alarm in your house also known as the "dinner bell"?
'99 Zetec VCT Daily Driver Mild Air Filter Mod
Posts: 134 |
no its like not a machine stopping type humming noise, its a really bad one. I think it had to do with the exhaust because, I dont know why thats just what I think it is. But its weird how the RPM keeps jumping and falling like that. Sometimes the noise will be there after I start the car, and push on the accelerater, then it will come on and start doing it, until i rev the RPM above 3-4K, then it will go away until the rpm comes back down and it will usually do it all over again. Thanks you though, I dont think thats what it is but thanks for trying to help anyways.
Anyone else??? O yeah, and the car is still under warranty, but I absolutely HATE ford service. I bought the car used so its not like the warranties you get when you buy a brand new car.
Thanks, Nomi
Posts: 1,461 |
Sounds like the "moose". My '95 V6 was affected by it, a TSB called for replacing the air duct. I think there's a TSB for the SVT models too, but I'm not sure. Maybe check the TSB section on the main site.
Brian
Posts: 5,805 |
'The Moose is Loose...they just love love the cold....!!!!
Posts: 3 |
 I just had that problem fixed on my 1999 SE Contour. The Ford dealership stated it usually happens on 1996-1998 Contours! Great! But it is a gasket either on the tranny or air intake. I am trying to locate my paperwork to tell you the specifics. I will e-mail you again this week if I find it and will tell you the specific parts/item. Mine just happened to be covered by warranty . Andy
99 Contour Se Spruce Green
Posts: 417 |
Ok my experiance, it's a combo of the PCV valve (or something like that) and the O2 sensor. Ford will fix it if you still have warranty. They fixed mine.
99 Ford Contour SE Sport Manual V6 SVT front/ rear bumper /w Aussie grille Jet black Premier DEH-P740MP head unit matrix display, plays Mp3s!! 800 watt Kenwood amp 2 12" Polk Audio subs Blue "euro" headlights Eibach Pro-Kit springs 17" Enkei RS-5 White Indiglow gages
Posts: 17 |
I am having the exact same problem as you Desiguy91... I actually just took my car into the shop on Friday and they said they had to order some sort of a sensor.. I was in a hurry and didn't look at the paperwork to close, but the part is ordered and should be here sometime this week... I also have a 99 Contour SE sport.
When I start my car in the morning with my remote starter.. I can always verify that it is running, cause I can hear the howling from inside my apt, grrrr.. thats how bad mine is.. and every once in a while it also does the messed up idle thing.. the rpms jump from about 1500 to 500 and just keeps doing that...
when you find out exactly what ford replaces will you please let me know, so that way I can compare what they do to your car and what they do to my car. Thanks in Advance
Posts: 3 |
Found it. They replaced the idle air control valve assembly. The Ford part # FMCXS2Z 9F715 BA. IT took 1 hr to install and problem has not occurred in two weeks.
Posts: 10 |
I had the same problem last year with my '99 SE sport - and ford replaced the idle air control valve assy. But, my car is starting to do the same thing again...I guess those things only last a year?
willyb '99 SE Sport
