#444330 09/24/02 11:18 PM
I know this has been covered before but search hasn't helped.
How do I get rid of the haze that's on my headlight lenses? I used an abrasive dish pad: no help. I used the dish pad with Ajax: no help. I think it's on the outside, but not really sure. Thanks.
'98 SVT KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10 JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17 / Bosch +4 / Ford Motorsport wires
#444331 09/24/02 11:33 PM
Try toothpaste, not the gel, but the paste, and a good towel. Worked on my girlfriends 95 Geo Metro.
If not then wet sanding is in order.
www.ChicagoCEG.com 2006 White Grand Prix
#444332 09/24/02 11:36 PM
TGO Offline
Someone one time recommended to me one time a product called "BON-AMI" It's a scouring powder, but it's not very abraisive, I'd probably try that and use a high speed buffer or something. You can gt it at your local supermarket.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#444333 09/24/02 11:52 PM
E
E
1500+ grit sandpaper, sand it down a bit, until its gone. Use some compound and then wax and you should be good to roll.
'00 Focus ZTS, 5spd: BONE STOCK!!!!! Buy American or apply for Japanese welfare. www.geocities.com/fordcontour05/contour.html
#444334 09/24/02 11:57 PM
Mine look hazy also. I've sanded down with 1000 and 2000 grit sandpaper, but it looks like the plastic is actually cracking (crazing, crows feet, etc) on the inside or somewhere inbetween.
E0 SVT, lightly modded
#444335 09/25/02 03:18 AM
Mine too,doesnt look like there is much to do about it,Its almost like the lenses are fading from the inside out.Cheap plastic I guess.
I AM WE TODD IT I AM SOFA KING WE TODD IT
#444336 09/25/02 04:40 AM
E
E
Have you ever had a burnt out bulb that when you took it out there was no bulb?
#444337 09/25/02 04:47 AM
what, run that by me again? you're sounding matrix-esque, there is no spoon...
#444338 09/25/02 05:36 AM
I just dealt with mine while doing that "hightower" mod. I wet sanded the ISH outta them w/ 1000 grit until some kind of clear coat came off of it. Then moved to 1500, then 2000 (when sanding that fine ALWAYS jump up only in 500 grit steps). Then I used Meguiars Mirror Glaze 85: Diamond Cut Compound 2.0 many times by hand (6 Mr.Meeaugi moves "Wipe on, wipe off") small half dollar sized swirls. THEN I used Meguiars Mirror Glaze Speed Glaze (light cut) about the same amount as before.
My lights look amazing!!!!!
That was WORTH it alone. Labor-o-love!
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
#444339 09/25/02 01:52 PM
I'd like to see some pics of the finished work! Do you have any?
Thanks for all the suggestions.
