#48884 12/01/01 04:56 AM
SVTee Offline OP
Does the throttle hang "fix" in the how to section really work? Mines hangin'!!
IAC was replaced 60 days ago, thought it fixed the problem...guess not.
Help, please. Thanks!
#48885 12/01/01 05:35 AM
Yes.
Buy two or three caps so you can experiment with different size holes.
Some feel that this modification cuts mid range power, others say it doesn't.
Try it and see. It is cheap, easy to do, can be done quickly, and is very easy to remove if you decide that you don't like it.
Jim Johnson
98 SVT
