Posts: 70 |
Today I decided to install the SVT upper I had and change my plugs and wires and maybe crack the secondaries. All went well until I was installing the bolts for the upper. I inserted a bolt into position 1 as per the chilton manual. I tightened it slowly with a torque wrench and "snap"...the bolt broke in half. Just a little part of it is above the lower manifold the rest is stuck below. The words that came out of my mouth I cant post here I continued the install and finished up due to the fact that I was so tired already. Now my manifold sits with only 5 bolts attaching it to the lower. Will this cause issues if I leave it for a while till I figure out what to do?
98 Silver Frost Contour SE Sport ATX BAT Handling Kit, SVT E1 Wheels, SVT TB, UIM, Airbox , SVT Exhaust, Rear Strut Brace, Pioneer Deck and 12 disc changer, Pioneer 6X8's
Posts: 3,419 |
Ouch, that can't be good.
I made sure I cleaned my bolts up by spraying with WD-40 and wiping with a rag before re-inserting. They didn't want to go in smoothly until I did that. Of course, too little too late for you.
I'd be worried about the gasket leaking and leaning out your fuel charge. Lean = Boom if you aren't careful.
Posts: 1,367 |
man that does suck! how much torque were you giving the bolts? i don't understand how it broke cause the upper intake bolts require very little torquing. you could practically tighten them down with a 3/8" ratched to a little more than hand tight.
Posts: 753 |
Originally posted by SilverAtx: Today I decided to install the SVT upper I had and change my plugs and wires and maybe crack the secondaries. All went well until I was installing the bolts for the upper. I inserted a bolt into position 1 as per the chilton manual. I tightened it slowly with a torque wrench and "snap"...the bolt broke in half. Just a little part of it is above the lower manifold the rest is stuck below. The words that came out of my mouth I cant post here
I continued the install and finished up due to the fact that I was so tired already. Now my manifold sits with only 5 bolts attaching it to the lower. Will this cause issues if I leave it for a while till I figure out what to do?You did realize that it was 71-106 lb-in and not lb-ft right? At about 6 lb-ft you should almost beable to remove the broken piece by hand. Good luck
Posts: 597 |
I did this on my mystique once...I rode around wiht one bolt broken for a while. I finally got one from ford like 5 months later...They aren't cheap...like $10 each. They might have to do some digging to get it for you.
00' SVT Contour, Black and Blue #954 of 2150 Stock....
2003 Red Fire Convertable Cobra due in September...
Posts: 1,421 |
i've got a bolt 4 ya try vice grips on it if theres enough showing
97 gsxr lotsa good stuff 4 sale 95 talon tsi awd turbo loaded sold 95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies custom y with hi flo cat,custom dynomax exhaust,upper cat mod superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Posts: 7,329 |
Good luck That's exactly what I was thinking! No possible way to break them at that torque rating!
Posts: 70 |
I think it might have gone in a little funny and I might have applied a little too much torque....just a little...aparently too much. Maybe these bolts were designed to bust to prevent destroying the threads in the lower because it didn't take much.
The car runs fine...it just bugs me that that bolt is busted. A little is sticking out but I would have to remove the upper to get a good enough grip on it to even think about it. It is supposed to rain for days now and I have no garage so..it will have to stay like this for a while.
Thanks for all the constructive comments... I have to go in for warranty work soon too....got some kinda fuel leak(not related)
10 bucks for a bolt...sheesh..thats what happens when you buy oe parts i guess.
Posts: 7,329 |
There is also a Specific torque sequence when installing the manifold as well. Not following it can lead to manifold warpage, leaks, and worse.
Posts: 1,479 |
Yes on torque sequence. Also the times I'e taken those bolts out, I put them in by hand with just the socket in my hand, screwing them down 'till they are just barely snug, then "wiggle" the manifold a tiny bit to make sure it's seated... THEN torque the bolts down in sequence. and i would use an antisieze on them too. (or a thin film of light grease, and torque accordingly)
One beat'99 Tropic Green SVT
