Page 2 of 5 1 2 3 4 5
ATTN Guys!
The struts will bolt-in using EXISTING bolt holes, ie, NO MOD. IS REQ'D!
The correct hole to use in the HOOD, is the hole NEAREST the windshield (hood in closed position).
The correct fender bolt hole to use is the hole that is nearly inline w/ the radiator water fill cap, ie, the hole just past the rectangular opening, towards the windshield.
Mine are installed as described & are working GREAT!
If you need to talk to me for clarification, i may be reached @ ph. 864.281.4300. If not there leave msg & i will call you back.
jay
jay bass
deltaman@mindspring.com jb@thedelta.com
'99 SVT Contour (tropic green/tan)
557 of 2760
Deltaman,
the simple bolt-in is nice. The original instructions in the how-to section use the ball mounts that come with the hood struts, and require drilling and tapping into the hood.
Demon,
I don't find the ball mounts causing any flexing on the hood. They do not cause any more strain than the ones described above.
I think that you may be referring to the fender flexing. For that I found a substitute mounting method at Pep boys that consists of a 8mm threaded clip that will clip over the fender lip.
teachertim
My F-150 is a '01, but I believe that any built after '98 will use hood struts. The Hood Struts are NOT compatible. The struts called out in the how to section are the correct ones to buy. The compatible parts are the ball mounts on the F-150 that screw into a flange on the fender well.
Hope this clears up any confusion on my installation method.
Delatman, good research on the current issue of hood struts for the Tours'. the original method in the How-to does need some improving.
regards,
david
2000 SVT #669
Wimpy Stock stuff
E
Eric L Offline OP
E
ttt
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
H
H
deltaman, r u using the exact struts that we bought in the group buy?
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
E
Eric L Offline OP
E
Didn't mean to alarm everybody on these, I was just a little skeptical after seeing Todras' post about damaging his car after his install. With the help of OutlawdSVT, they are on and look AWESOME!! Here are te pics of htem installed, they work prefectly and look killer!!
WooHoo laugh laugh
svt1675@comcast.net
LOOKS GREAT!
So was there any particular reason you didn't use the top bolt? How well does it stay open?
Also did you have to thread anything? Or did you just screw the ball into the hole. (After removing the bolt?)
Again looks great! Can't wait till mine come in!
Later
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
1
1
Good job...I just gone mine today and will install tomorrow. smile
Silver Frost 2000 SVT #1443 of 2150
Mirror Tint/ Momo shift knob/ Kurtz Kustom pedals
Ventshield raingaurds, moonroof and hood bug deflectors
True Rev Induction Kit/ BAT Air Inlet Pipe
Philips HID kit/ PIAA superwhite fogs/ Chrome Gas Bonnet Lifters
Top of line Alpine system( NVE-N851A, DVA-5205, IVA-C800, TUE-T011A, KCE-150V, CHA-S624, PRA-H400), PPI (PC 4100, PC 2150,PRO 10's), Image Dynamics CD2 Comp MH and IDQ-62.
Motorola Timeport HF car kit
Looking to increase performance!
http://photos.yahoo.com/hpick1
Future Mods waiting to be put on:
Lotek Guage Pod w/ volt, a/f ratio, and oil pressue.
Blue neon undercar kit
Aussie Bar w/ upgraded backing plate
Bullitt Fuel Door
Magnacore Wires
Ground Control Kit w/ Koni Struts
E
Eric L Offline OP
E
With Top bolt on the hood, the strut will not collapse enoguh to allow the hood to shut, we tried it.
Install was a breeze, tighten the hood bolt that remains in, and remove te lower ones and insert the non-self-tapping screw in that hole. Remove the bolt from the fender, and insert the self tapping screw, making sure to use washers in both locations. Pop the end pieces on, and insert the clip.
The hood stays open great, they are not quite strong enough to open the hood w/out human help, but once open they do stay just fine. Closing is quite simple, just push down gently on the hood and guide it wo where you usually drop it to engage the hinge.
I also removed all the writing on them with some Chrome polish and some fine steel wool.
Got any other questions, drop me an e-mail.
svt1675@comcast.net
Krikie those pics are HUGE! Thanks for the tip guys I'll use the lower holes as I had planned. I knew we'd figure out a way.
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
Could someone tell me the parts numbers for the mod? I tried Search, but my computer kept screwing with me, so I gave up. mad
Black/tan early '98 Contour SE Sport; V6, MTX, loaded
Kenwood KDC 316S CD deck; aux. dome light mod; trunk popper spring; resonator bypass; hood strut mod; SVT grille; Continental tires
Mom also has black/tan '98 Mystique LS; V6, ATX, Alpine CD deck
