From the Ford TSP:
P0420=Catalyst system efficiency below threshold (Bank #1)
Possible causes: -- Use of leaded fuel. -- Oil contamination. -- Cylinder misfiring. -- Damaged HO2S. -- Damaged ECT sensor. -- Downstream HO2S wires improperly connected. -- Fuel pressure too high. -- Damaged exhaust system pipe. -- Damaged exhaust manifold. -- Damaged muffler/tail-pipe assembly. -- Damaged catalytic converter.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
