Anyone ever have a similar problem - I'm getting a small amount of leakage
down the front of the engine from directly above the oil filter. I'm
thinking it might just be sloppy pouring - 'cause the oil path if you miss
the hole would be almost directly down the front and onto the filter. On
the other hand - I first noticed it when changing my oil last weekend, the
old filter had oil run lines on it and now after 5 days the new filter does
too.
Anyone know what is in that general area that could leak? I assume it'd
have to be something like the valve cover gasket - or is the oil sender in
there above the filter?
