Originally posted by bk4293: OEM means buy them directly from Ford, Not autozone or anyplace else.
Not true. You can buy O2 sensors for our cars at other auto parts stores. Ford will charge almost double the amount (~ $120-130) for an O2 sensor. Just make sure that the O2 sensor comes with the correct connector.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
