Posts: 12 |
1999 Contour SE 37000 miles........................ My O/D light started flashing and a few miles later the check engine light came on. I took it to a dealer who ran a diagnostic test of everything....cost me almost 200 bucks and they said there was nothing wrong with it and they cleared the error code. Well.....that worked....unitl the next time I got on the highway for more than about 5 min. Yes....I took it back and they said they could run the test again and NO it was not free.....SOOOOO...I took it somewhere else....again no problems and after a few miles the light starts flashing at me again, Oh and this time it also shifts real hard in the lower gears. I checked the tranny fluid....it is good. Anyone have any ideas on the problem (other than its a Ford)? Thanks! Oh yea.....we have gotten the dash replaced twice and it is warping again. grrrrrrrr
Posts: 122 |
I have the same problem. I just posted almost the same thing in the Transmission forum. I have a 96 GL ATX.
Posts: 3,732 |
that happened to me once, i was going 90mph. i hit the OD button, not a good idea. dropped it into drive (light still flashing) went from 90 to 70 in half a second lol. scary as [censored]
Russell
Oval Port 3L Nearly Done
Posts: 12 |
I guess no one knows what it wrong.....oh well........took it to Autozone for the CEL.....said there was not a problem! I knew I should not have got a ford grrrrrrr
Posts: 1,412 |
Posts: 2,319 |
I haven't seen a conclusve post on this subject yet. Here's a recent thread which includes my own experience. If you want to change something to see if it works I would suggest the air in your tires, cheaper than plugs and probably has the same corelation.
Posts: 17 |
whenever I've seen flashing O/D lights(on other cars, not contours), it is a speed sensor. This could be it, if you also have hard shifts, but is your speedo working fine? Anyway, a good mechanic can test a speed sensor.
99 Silver SVT Contour. Run o' the mill mods.
Posts: 34 |
I had the same thing happen to me. When mine did it, the transmission shifted hard into 2nd aswell. I brought it in and it turned out to be a clogged transmision filter. So after being flushed out and getting a new filter it stopped. I think the car decided it hadn't cost me any money in a while so it deceided to act up  .
1996 Mystique GS
Zetec, ATX
