I started changing the plugs in my V6 but i cant get the last two boots off the damn plugs! ARGH!!!!!! how do you fit your hands in there?? This is SUCH A PAIN IN THE ASS!!!!
Please help me asap.. i need some advice on how to get the boots off... the job is half done. i dont want to give up but my patience is running thin...
thanks jca
PS i'm talking about the plugs that are top right and top center.. near the distributor.
The second last time I pulled off the rear boots, I put rubber tips (surgical tubing)around the tips of the pliers, which in my case were long surgical clamps ( no longer being used in an operating room).Worked OK and the engine purred along but,after a few thousand km's the plug wires became bad, and were replaced..I must have damaged them slightly at removal and they must have degraded more over time . If you experience sudden ignition problem in the not too distant future, it will most likely be the wires. Take care.
stock 95 LX,6cyl ATX
98.5 wheels with Yokohama AVID T4's
