I too am getting a 3-2 code on the airbag light. Could someone please translate this into layman's terms that I might understand:
The air bag diagnostic monitor measures the resistance across Pin C2-10, Circuit 31S (BK/O) and Pin C2-11, Circuit 8 (W/BL) every time the ignition switch is turned to RUN. Normal resistance across these circuits is between 1.5 ohm and 2.0 ohms. This resistance comes from the air bag itself (approximately 1.0 ohm) and the air bag sliding contacts windings (approximately 0.25 to 0.5 ohm per winding, two windings in all). If the resistance across these two circuits exceeds 4.0 ohms, the air bag diagnostic monitor will flash Code 32.
What would a dealer (or independent) mechanic do to fix this or, since I am not all that happy driving behind these two bombs in the dash anyway, can/should I leave it alone?
