Been there..did that...and yes, you can do it that way. I'm sure someone on here will tell you why its bad, and why its better to take it all apart. With a partner the ole push down/pull out will work..I did it by myself and it was hard...but I'm 225lbs and work out all the time. Easier to just remove the lower arm. Remove the nut...hammer out the bolt...pickle fork and she's dropped. PM Terry Haines for any more Qs.
