Posts: 16 |
Hey all,
I've done transmission filter changes before on a 96 Taurus and 98 Intrigue and it was a piece of cake. You just drop the pan, drain the fluid all over the place, pull out the filter, push in new filter, reinstall pan and gasket, and refill with Mercon AT fluid. So when I bought this C 2 months back with 59K on it, I just went to Ford dealer to by a trans filter figuring I could do it myself no problem. Well, last night after spending 5 hours screwing around taking out the battery support and trying to get this vertical pan off and then realizing there was no trans filter right behind it to be replaced I figured I'd come here for help. Can anyone tell me where this filter is and should I even mess around trying to replace it? If not, I'm probably stuck with this filter cause the dealer won't allow me to return it.
FYI - I ended up just doing the Haynes drain-fill-run-drain-refill and went to bed.
98 SE V6 Dark Toreador Red
Posts: 8,301 |
There is no filter, just a screen, that as far as I know, cant be replaced without taking the tranny apart
Hopefully Terry will be here soon to tell me Im right, or full of it  but Im pretty sure Im right.
-Ken V.
psycho_bass@hotmail.com
Posts: 1,603 |
CRZYDRVR, YOU'RE ABSOLUTELY RIGHT ! The wickedly stupid CD4E DOESN'T have an ordinary filter like the rest of the automatic transmissions do. I wonder who's bright idea was this...
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 1,044 |
I've gone to yearly changes with synthetic fluid to keep it clean/fresh.
Posts: 8,301 |
CRZYDRVR,
YOU'RE ABSOLUTELY RIGHT ! In reply to:
WOO HOO!!!
-Ken V.
Posts: 16 |
Thanks for the info. If there is no filter then what in the heck did I buy from the dealer?! I simply told them I needed a filter for a 98 Contour with the V6 and they sold me this filter for $28! They will see today about this.
Posts: 429 |
There is a filter, it is accessable only by some amount of tranny disassembly. I bought and and returned a filter kit a few years ago that had a large plastic filter with some sort of felt-type element. i gave up on removing the side pan since it was too difficult. Look into the Magnefine, which splices into the cooling line.
Dan B.
96 SE 2.5 auto
Posts: 192 |
What is the least cost approach to run these suckers into the ground?
Outside Filter Whos $$$ ?
Haynes 3 Qt Drain ?
Drain and FILL with 4 people and hoses Tanks Etc?
THANKS
1999 GREEN Contour SE SPORT Duratec V6, ATX, SUNROOF, 93,000 Miles, P0420 ON&OFF -replaced DS O2 --did not FIX
*New TORQUE CONVERTER @ 53,000-Intermittent P1744
*New DASH at 53,000 and New DASH lifted-now using MOLLEY bolts to pull down
Posts: 263 |
1996SE sports package, Duratec MTX No mods yet.
80K Kilometers.
Wife has 1996GL Zetec ATX.
