Originally posted by JSmith:
.. the slight low presure it maintains in the crankcase can proportionally increases the pressure differential across the piston rings which helps them improve their seal...
Perhaps you could blow-that-by me again, since it does not compute.
PCV valve lowers crankcase pressure compared with old breather type due to vacuum of induction system.
Contour98SVT:
Under throttle body on v6.
Dealer will replace at n/c at 60K, except here and CA.
