I believe there's just one indicator, for the vertical direction. Adjusting the hex screw next to the level should move the bubble around. As for the horizontal alignment, it's pretty much up to your own preference. For both adjustments, find a level spot near a wall and turn your lights on. I leveled mine the other night and the vertical height of the center of the beam was approximatley 22.5 inches (measured with a tape measure). For L/R alignment, I keep my driver's side light aimed just slightly toward center and the passanger light pretty much straight out. But again, the final tuning really depends on how you want the lights to work. Hope this helps.
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue
Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
