I recently replaced the engine in a newly acquired 95 contour with the 2.5 I never drove the car before engine swap and now that it is back together the car shifts hard between first and second when you give it some throttle it will actually chirp the tires and the overdrive is not engaging even when you push the console button. The transmission seems fine after that, however it does down shift a little hard and if you drive it easy you don't notice it as much so I am wondering if maybe I missed something on engine swap.Does anyone know if the contour has a vacuum module or not ? .
