Well, seeing as the flywheel is only like 10 or 11 inches diameter, and the pulley is about 4 or 5 it's not as insignificant as all that (inertia increases with the square of the radius - 2x radius is 4x inertia). But you also have to consider that 80% of the pulley weight is at max radius (from the damper ring), compared to a roughly equal distribution on the flywheel so it gets even closer. I think 4 lbs off the pulley is roughly equivalent to 1.5 or so on the flywheel the last time I napkin-calculated it. Going up 5 lbs from UR UDP to DMD would without question be noticeable, going from stock up 1lb to DMD would probably be hard/impossible to feel - and well offset by the increase in smoothness.
97 Contour SE MTX
04 Grand Caravan SXT
