Did it my self, Cost under $10.00.
Theres screws not clips.
For the piece above the dash theres 5 screws 2 behind the Contour plate(or clock) 2 above the sppedometer, and 1 behind the defroster switch.
For the headlight sitch you need to take off the panel below the steering wheel, there are 4 screws on that, do not try to pull it off, it is connected to a metal plate, and those 2 pieces are a pain to get back together, once you get the 4 screws out it should come right off. Once you get that off there are two screws holding the lightswitch trim on, take those out and pull it off there are clips there.
As for the stereo trim it depends on what year you have.
Wet sand all the pieces down just to get the shine off, primer, paint (2 coats of paint should do) then clear coat, maybe 2 more coats.
The paint I used I bought from Walmart. Nothing fancy, just some sprayb paint out of the Automotive section.
