#438540 09/16/02 03:25 PM
TGO Offline OP
What's the pattern? Front left to Right rear?
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#438541 09/16/02 06:20 PM
E
E
Depends on what type of tire you have. Directional tires stay on the same side of the car and just rotate front to back and back to front.
Non-directional tires should be rotated fronts to rear without changing sides and rears to fronts in opposite directions. Left rear to right front, right rear to left front.
You can do it other ways, but I believe this is standard.
1998.5 E1 SVT Contour #5482/6535
#438542 09/16/02 10:51 PM
TGO Offline OP
How can you tell if your tires are directional or not?
#438543 09/17/02 12:19 AM
if you have the KDWs they're directional. directional tires have tread that usually "points" towards the front, and hence that is their direction of rotation. they usually have an arrow on the sidewall, too, poining in which direction the tire should turn.
so, if you have directional tires, it's just front to back. HTH
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
#438544 09/17/02 01:55 AM
Isn't there a way to X rotate directional tires because you can flip the tire over and the tread will still face the same direction...
Matt
#438545 09/17/02 12:02 PM
The only way to X rotate directional tires is to have them remounted on the rims on the other side. X rotating is not necessary for most drivers these days. Front to back, back to front is all that is most tire shops do every 6k miles.
#438546 09/17/02 11:53 PM
Usually the only reason to dismount tires for rotation is if you own a Corvette or Viper or something of the like, where the front and rear tires are different sizes. Of course, you can't do this if the tires are both directional AND asymetric (meaning they have a rotation direction and are left/right specific).
For those of us using directional tires, front to back and back to front is just fine.
Moderated by  1314_dup1
