RH primary crash sensor feed/return circuit open. Looks like a wire is off somewhere. Did you work on anything on the front end (like drain and refill coolent)and knock a plug open? First thing I would look for before going to a shop. If you are unsure of what your are doing, leave it alone. Airbag is like a shotgun trigger on a tight string!
