#436854 09/13/02 05:42 PM
S9V8T Offline OP
I need helppppp!!!! aghhhh...ive seen previous ppost up . I have a 98 svt and my ac and heater have stopped working. I t was working one minute and the next it stoped. I can hear the vaccum hoses releasing air but it will not kick on when it is turned to ac or heat??? help I also tried to locate the resistor stated on previous post but can not find it . I did find a white box on the passengers side but it has a harness and is up in ther by the left leg side??? any comments or suggestions???? thanks... greatly appreciated
#436855 09/13/02 09:00 PM
Resistor only affects lower speeds on the fan, IE: you can only run full speed. Did you check fuses? There is one under the hood as well as under the dash. I burned up a 40 amp fuse under the hood that killed the fan and A/C (Don't ask how :angry:.
There is a 15 amp under the dash fuse for the control panel.
Check all fuses before going too crazy.
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
#436856 09/15/02 02:03 AM
S9V8T Offline OP
would the se be the same as the svt??? I checked all the fuses and they all seem fine I know there is a relay for the ac under the hood. Could that be it?? Or could it just be the blower motor? Winter is just around the corner and I have neither. Just imagine the heat in west tx, and boy the winters get cold with snow beleive it or not. Guess I'll start with the relay first.
#436857 09/15/02 03:34 AM
I am sure the SVT has the same fuses underhood. There is a big 40amp job (about 3/8 inch square, green IIRC) for the A/C. F42 underhood. Under the dash, there are 2 fuses: F37 (30A) for the blower and F23 (15A) which is labeled for backup lamps but shows on the schematic on the tech CD as working the A/C controls too. Makes sense as 15A would be too high for just a pair of lamps. Check all three. Check owners manual for location. Fuse #s are listed without description on the fuse box covers.
#436858 09/16/02 05:34 PM
S9V8T Offline OP
thanks I'll check again
