#436645 09/13/02 06:48 AM
I can't take off the license plate on my Contour because of a stripped screw. How else can I get to the license plate from the back? Is there a way to remove it so that I can put a license plate holder on it? Please help me!!!
#436646 09/13/02 11:10 AM
I'm assuming you're talking about the rear plate. You might try using a screw extractor(sears sells them)they can work pretty good. Or you might just try drilling out the screw so it can fall out. You can remove the entire rear black piece on 98+ cars with just about four nuts on the back side. Then you might try removing the license plate from the rear side.
#436647 09/13/02 02:20 PM
alright. i just recently had this problem. i guess it wasnt the problem that i couldnt get the screws out. it was the problem of not having anything for the screws to hold on to. what i would suggest is going to ford and paying something like 12 dollars to get this replacement part that basically reinstalls the two holes on the top to new. and if you choose, you can do the same with the bottom but not neccessary. the kit requires you to drill out the top two threaded areas with a 5/8in hole cutter. so it probably wouldnt hurt to drill out the screws if you were going to go this route. just make sure you do a clean job and dont break the plastic.
oh, and to answer the question about getting the screws from the bad. will require drill since they do not go through. there are just bumps in the back side where the screws would be...a design of the part.
hope this helps. let me know how things go.
