I will reset the computer. Changing engines out went fairly well with a few sensor changes and I had to swap out intakes, but I did stay with the same computer, wiring ,etc and feel pretty confident that the engine swap itself has no bearing, however I thought it a good idea to mention it just incase there maybe something that I have over looked.I know on older cars that you had a C.V cable on the tranny that you could adjust which in turn changed the shift point as well as the harshness of shift.I really don't know if there was a problem with the tranny before the engine swap because I bought the car not running and the fellow I bought it from is avoiding me I don't know why he won't talk to me I knew that the car needed work and that it was as is where is.
