#435782 09/12/02 01:13 PM
AzNHxC Offline OP
I'm lookint to slowly upgrade the performance in my car...eventually ending up with a turbo or a nitrous..what kind of mods should i start out with...pretty much i have about like figure around 300 bucks a month or so to spend on mods..my cars stock except for audio...would it be possible to maybe find a junked contour and use that engine to be bored and polished...someone i know said it would be good for around 40hp..any help would be appreciated...
-//Stefan//- Aim: TearGasParade
#435783 09/12/02 02:22 PM
Well you can do intake and exhaust. That should take up a month or twos allowance. After that there is chips, LSD, etc.... Lots of stuff to do with the Zetec.
-Colter My Old Car Current Cars- 1999 Ford Taurus SE 3.0 Duratec 1999 Ford Explorer XLT, my Geocaching car.
#435784 09/12/02 03:24 PM
a LSD on a ATX
2003 Subaru WRX some mods Even if you don't have the answer, you certainly have to admire the problem. aka ZetecRacing
N
N
Any of you know what the throttle body size is on the Zetec? Also, what is the size of the one on the SVT Focus if not the same will it fit on the Zetec Tour? Just an idea I had earlier, not even sure if it is really worth the trouble. If this question is more of a vehicle specific question refer to my sig. Thanks for any input y'all have!
Kyle
Kyle 99 Silver Frost Tour Zetec MTX Mods to Date: Removed Silencer, K&N Drop-In, JDM Tuned Superchip Planned Mods:Many to come hopefully
#435786 09/12/02 10:28 PM
AzNHxC Offline OP
What kind of exhaust should i look into how big of pipes should i get and what kind of muffler...should i get like a high flow resonator or just have it straight from the cat...and do they have high flow cats???
#435787 09/12/02 10:55 PM
get kamikaze header made for zx2 fitted to your car,,,, then get hi-flow cat,, then get borla cat back.
#435788 09/13/02 12:43 AM
O
O
In reply to:
yes its possible, but I doubt boring out the block would give 40hp, unless you dropped in a crower stroker kit, along with the rebore. On 300 a month you should actually be able to rapidly improve you contour. I personaly think think the intake tract and head have the most gains to yield over any other component. If street flight ever gets the Cold air intake on the market it will probably be the premier contour zetec intake, virtually eliminating the horrible heat soak our cars experience once warm. Underdrive pulley is also another good mod that can be done in your drive way and will not even take up half of your monthly tinkering money; a new valve train and head work will net you the most gains over any one single mod, but is much more expensive than your average bolt on.
In reply to:
Good luck finding a place that sells the kamikaze anymore(zxtuner.com, where loco got his, has a new 4-2-1 header that they say can fit a contour, but they are not yet even being shipped and are already on back order for months), I agree with the hiflow cat, but skip the Borla SVT exhaust, the quasi-dual setup is just for aestehtics any way, and the Zetec doesn't need that much flow area, or the weight of an extra muffler. Get a brullen system or custom mandrel bent system(like me), and they are the proper size for a zetec and will probably give the most gains.
Ohsigmachi '96 GL MTX Zetec --I don't won't to hurt you, but it's still on my list of things to do.-- View projectSlippery Slope
#435789 09/13/02 01:58 AM
The SVT quasi dual showed a 3 hp gain for D Davis.
#435790 09/13/02 02:56 AM
O
O
as opposed to a possible 6-8 hp gain for the lighter brullen system.
#435791 09/13/02 03:13 AM
AzNHxC Offline OP
Where can i find the brullen system...thanks alot for all your help...im going to be doing more research as i wait for the proper funds to come in...oh and high flow cat where can i find me one of those bad boys...
Moderated by  Loco4G63
