I have 2
? Bridged Max Power: 1200 Watts
? RMS @ 4 Ohms: 250 X 2
? RMS @ 2 Ohms: 300 X 2
? RMS Mono: 600
? Full Mosfet Power Supply
? PWM Circuitry
? Full Selectable Crossover Hi / Full / Low
? Three Way Protection Circuit
? 2 Ohm Stable Stereo
? Tri-Mode Capable
? Variable Low Pass 40Hz-120Hz
? Variable Hi Pass 150Hz-1.5Khz
? 18dB Bass Boost @ 40Hz.
? Frequency Response: 10Hz to 30Khz
? S/N Ratio: 97 db
? THD: 0.02%
? System Distress Indicator
? High/Low Level Inputs / Floating Ground
? 4 Gauge Power/Ground Connection
? Gold Plated RCA Connectors
? Line Output
? Dimensions: 20.5" X 2.25" X 11.25"
and 2
FUBR-12
? 1800 watts power handling
? 200 oz. magnet
? 2? ASV voice coil
? SPL 91 dB
? Sealed box: 1 cu. Ft.
? Ported box: 2.2 cu.. Ft.
? Tuning: 34 Hz
? Port Size: 4?(dia)x12?(length)
? # of ports:1
the sound is great but i figure you can never have too much
